[email protected]
I have an old beat up ford 4610 that runs well and is very useful. However somewhere along the line the lift arm levelling assembly was replaced with chains instead of the forged arms that do the work of both vertical lifting and also positioning of the implement. The chains transmit lift but no stability and they need to go... On one side, the hydraulic lift arm knuckle pin has been replaced with bolt, but on the other side it is still a very stout pin that looks like it has been pressed into the holes and does not want to come out readily. THis needs to come out so I can install a new leveling arm assembly. Is there a trick to the removal of the pin? Do I remove the entire hydraulic lift arm (that attaches to the many splined shaft beneath the tractor seat), then drive it out with some heat? Thanks!
