64 3020 gas engine is locking up
  • Thread starter Thread starter bv
  • Start date Start date
Update with pictures
I got my son to help set the head off tonight and wiped it down a little and used some emery cloth on the top of the sleeve and it cleaned up pretty good, I think I’ll home it and see what it looks like then, thank goodness #1 was almost to the top because it’s the only one that got water in it due to a straight shot through the open muffler
And the engine turns over without locking up so I was using a small bar when trying to turn the engine and didn’t try to force it so I appreciate everyone who helped me with this project! I think I’ll get the head looked at just in case, thanks again.
After I hone the cylinder if there is any small pits at the top close to the top ring will this hurt anything?
It will be fine. With small pits. The block is difficult to source. The piston and sleeve are common. I believe they are the same as the 4020.
  • Like
Reactions: bv
do I need to use Deere head gasket of will aftermarket do fine?
I had a head gasket leak from a jobber O/H kit I installed in a 3020 a few years ago. The fire rings did not crush properly / enough allowing the gasket to leak coolant around the ports and into the crankcase.
A little research on these forums and elsewhere showed that other people have had bad luck with certain aftermarket head gaskets.
I'd stick with OEM if it were me....
Yep even if you get a kit for everything else I’d purchase an individual head gasket from Deere
