drsportster
My wife has an od clock that seems wound way too tight . If I get [or make ] an unwinding tool will that fix it ?
You can't wind one too tight, they are designed to wind the springs by hand until they stop. The only way to wind one too tight is to turn the key until it stops and then put a wrench on the key. That would probably break the spring.My wife has an od clock that seems wound way too tight . If I get [or make ] an unwinding tool will that fix it ?
I think it is wound tight because the keys can't be turned further
Can you remove the case and see if the spring is completely wound. It's normal to not be able to turn the key any further if the spring is wound tight but if the spring is broken sometimes they get into a bind and the key won't turn. It's not really a diy thing to replace the spring. The mechanism would have to come apart and have a new spring installed. Just getting the broken spring out is bad enough, it will want to unwind and it has sharp edges.I think it is wound tight because the keys can't be turned further
can you work the balance wheel? flip it with your finger or a q-tip. try to make it tick.I think it is wound tight because the keys can't be turned further
I agree with Stephen that you can't wind them too tight unless you put a wrench to it. In addition, I would say the you more than likely need the clock mechanism cleaned, oiled and adjusted by a professional.You can't wind one too tight, they are designed to wind the springs by hand until they stop. The only way to wind one too tight is to turn the key until it stops and then put a wrench on the key. That would probably break the spring.
What is it doing that you think the spring is wound too tight?
