Farmall plowboy
I need some ideas how others cut through pink foam insulation, A regular utility knife don't get all the way through, and leaves a rather jagged edge. Thanks Craig
oogle search hot wire foam cutter and see if you may want to build one. They work very well.(quoted from post at 11:45:17 01/21/17) I need some ideas how others cut through pink foam insulation, A regular utility knife don't get all the way through, and leaves a rather jagged edge. Thanks Craig
