lastcowboy32
I've had a sporadic knotter issue. I've gone hundreds of bales with no problem, then... had three or more break on one wagon.
And I think I've made it worse.
It was just happening at the twine switchover. And when I looked at the broken bale in the wagon, I would find one twine with either no knot, a knot in one end, or just a swirl in one end.
I started with an assumption, probably my first mistake. That assumption was that my twine discs would be the problem, since they are old and worn, and just about everything else on the knotter has been tuned to the manual.
So, if you have trouble holding the twine, you run thick twine, right? I ran 7200 sisal. That should hold in the discs, right.
And it did, except at twine changeover.
Well, no knot in the #1 twine means the twine discs aren't holding it (among other possibilities)... so... I tweaked my discs a little tighter.
The problem got worse. I was baling away from home, no time to get a manual and read/troubleshoot... but I thought... jeez... there is no way that twine discs being too tight can cause this problem, so I tweaked them a little tighter...
Well, it's an off day, and I went through the troubleshooting guide. Apparently, no knot in either end... or no knot on #2 twine could be twine discs are too tight. So, now I have to go back to my original settings, next time I bale...
All of this would be a moot point, if I could tell after the fact, from looking at the remnants of a broken bale in the wagon, after the thrower has blown it apart... which end is #1 and which end is #2.
My guess is... there's no way to tell... but I've been wrong plenty of times. Is there a way to tell???
