1 Wire Alternator
super99
Changing my 1850 from original 3 wire with regulator to a
1wire. Do I have to unhook the wires from the regulator or
can I just leave them hooked up?
There was a ground bolt on the new alternator, so I
hooked the old ground wire to it.
My 1550 had a 1 wire on it when I got it. No regulator and
the wires just hanging there. Not sure if I need to
disconnect wires from unused regulator or just leave it
alone. B Thanks,Chris
Doesn't really matter as far as function.
It would look better is you took it off and clean up the wiring. One less thing to possibly ground out.
(quoted from post at 18:44:45 01/24/23) Changing my 1850 from original 3 wire with regulator to a
Why on earth install a one wire in place of a three wire ? Battery drain . Needs high rpm to start charging .
I have a couple Cubs with Delco
one wire alternators, they start
start charging immediately, at an
idle...... I always unhook the
negative battery cable, when not
using, in case mice chew up
wires, short things out and start
a fire, hence no battery drain.
(quoted from post at 22:04:17 01/24/23) I'm running about 10 1 wire alternators,they charge at start up and no battery drain.
o battery drain , in your mind, but it is there. You can not prove that it isn't. Does it matter to you....obviously not. But don't try to fool the rest of the world with false hoods!
I have three tractors with the one wire Delco, all three charge right away after starting. All three have a very slight current draw with engine off, not a problem IF they only set unused up to two or three weeks. Any longer and the ground cable is pulled off or the ground disconnect is turned off. My 560D has two batteries, and one time it set in the shed unused for four months, batteries were completely dead as I forgot to turn off the ground switch. They charged back up OK, and I remember to use the switch now.
(quoted from post at 00:06:51 01/25/23) I have three tractors with the one wire Delco, all three charge right away after starting. All three have a very slight current draw with engine off, not a problem IF they only set unused up to two or three weeks. Any longer and the ground cable is pulled off or the ground disconnect is turned off. My 560D has two batteries, and one time it set in the shed unused for four months, batteries were completely dead as I forgot to turn off the ground switch. They charged back up OK, and I remember to use the switch now.
ep
I have a David Brown 780 with a 1 wire alternator it sits usually from Oct to May with the battery hooked up,it fires right up no problem to go rake hay.Really you should get some knowledge before calling me a liar,I'd love to for you to come by my place so I could school you on 1 wire alternators.
I'm with Steve and Old it doen't matter for function just less to contend with later or cause problems. The battery wire could possibly be used from the regulator as long as it goes back to the amp gauge or volt meter and not through the old regulator same with the ground direct to ground.
Id wrap the other wires on the one your doing and the 1550 up with tape to protect them in case someone wants to put it back how it was. Not to mention there could be power there that could cause a spark if not unhooked farther back
Lots of reasons, especially if you are converting from a generator. We even build 6 volt positive ground alternators. Putting one together
today. I have not had the problems you talk about. We love them.
(quoted from post at 20:32:36 01/24/23)
Can't prove that it isn't there? Ever heard of an ammeter?
(quoted from post at 11:25:36 01/25/23)
Exactly! If he has the instruments & user knowledge he can measure the drain and verify what I said, i.e., the drain is there and he is just unaware of it. That is a fact & in no way calling him a liar.....those were his words, not mine.
