Zhaque
I will try to make this short.
My 1020 is or was equipped with a marvel schebler TSX 804S carburetor. I took it off with every intention of getting it rebuilt and then putting it back on but can't find anyone in my area who will rebuild it. A dealer is out of the question simply because it would be too expensive.
I inquired at the dealer as to the price of a new one and they quoted a little over a thousand dollars, so that's out.
I finally ordered one from all States Ag that is supposed to fit a 1020. However, it is a Zenith style 14996A and am wondering if it will work. If not, of course, I will send it back and try to make other arrangements.
I would really like to get the tractor running again before the snow starts flying, which in Missouri could be any time now.
Thank you for your time and I look forward to hearing from you.
Looks like the parts catalog calls for a TSX 904. PartsASAP shows a TSX rebuilt that is supposed to be suitable for use in place of the TSX 904, along with some other TSX models. I would call and ask about that one. PartsASAP may rebuild your carb if they don't have one rebuilt.
Check out this thread.
Possible carb rebuilder.
These are pics of the carb. Clearly, the tag reads 804S/ Not 904.
According to some info I came across, the 804S was used on a Case 301crawler tractor. I will go to parts ASAP and look around there.
Guess I'll send the Zenith back/. Thanks guys.
I was not doubting you saying it is a TSX 804. I am just saying the 1020 parts catalog calls for a TSX 904. You might have better luck finding that one.
That carb is not too difficult to rebuild, get a kit and check out U-Tube. You might be able to get someone local to rebuild it. Look for someone with old tractors in the yard or a trailer with a Street Stock.
