1020 hydraulic knock
I recently bought a nice looking 1020 diesel. When I bought the tractor the previous owner told me the hydraulic pump had been recently rebuilt. Problem is I hear a ticking/rattle coming from the pump. The noise sounds a lot like a shaft hitting something.
I have looked to see that everthing is tight from the install and that I have enough hyd oil.. When using a mechanics stehoscope the noise is definetly coming from the pump but is deafining when i put the scope against the suction line but not so loud when placed against the pump. Now for the part that must mean something??? The chatter is constant and continues when I lower the 3 point arms but stops during the time it takes the arms to travel up. (The arms operate fine... Not sluggish or slow.)
Any ideas would appreciated since I would like to have this ready to use a a rake tractor this coming hay season.
Are you sure it's not the rubber gromets in the coupler to the crank? Or the lack of them?
You'll have to take that plate off the bottom so you can get ahold of it and try to wiggle it.
We have a 2130 that had a similar knock. One day we finally
changed the long overdue hydraulic filter an the knock went
away. I figure it was the filer bypass valve opening and
closing so much.
There is also a wee screen filter in the front pump inlet.
I'll try and find the part number for it and the screens for the larger pumps tonight.
(quoted from post at 09:32:35 02/23/11) There is also a wee screen filter in the front pump inlet.
I figured this might save you some time for more Honey Do's. Filter is the same for 3020/4020
R27173 FILTER ELEMENT
Thankyou Txjim. For speeding time on a computer,
leaving me free to go and thrill Mrs B&D for a
while.
That filter screen is a popular item. It's use
din the following equipment.
690 - 3010 Grove & Orchard, Row-
Crop Standard & Utility Tractors (s.n. -049,999) -
01Jul08
691 - 4010 Tractor - 01Jul08
803 - 5010 Tractor - 01Jul08
858 - 3020 (S.N. -122,999) Row-
Crop Tractor - 01Jul08
859 - 4020 (S.N. -200,999) Tractor
- 01Dec09
860 - JD500 Tractor - 31Jul06
861 - JD600 Tractor - 02Nov06
957 - 2510 Tractor - 02Jul08
970 - 1020 Tractor - 02Jul08
971 - 2020 Tractor - 02Jul08
972 - JD300 Series Tractors -
02Nov06
973 - JD400 Series Tractors -
02Nov06
978 - 5020 (S.N.-024,999) Tractor
- 02Jul08
984 - 760 (Tractor Unit) Elevating
Scraper - 31Jul06
1032 - JD500 Series A (-123113)
Backhoe Loader - 06Jul06
1058 - 570, 570A (Automatic Blade
Control System) Motor Graders - 06Jul06
1068 - JD544 and JD544A Loaders -
06Jul06
1088 - 4520 Tractor - 06Apr10
1096 - 540 and 540A Log Skidders -
13May04
1110 - JD644A Loaders - 15Jul05
1115 - 3020 Row-Crop Tractor (S.N.
123,000- ) - 06Apr10
1116 - 4000 and 4020 (s.n.
201,000- ) Tractors - 06Apr10
1121 - 1520 Tractor - 06Apr10
1128 - JD500 Series B Backhoe
Loader - 02Nov06
1145 - 2520 Tractor - 06Apr10
1153 - JD760 Series A Tractor -
02Nov06
1155 - JD700 Series A Tractor -
31Jul06
1156 - 5020 (S.N. 025,000- )
Tractor - 06Apr10
1176 - JD500-A (123114-152141)
1226 - JD310 Backhoe Loader -
03Nov06
1227 - 410 Backhoe Loader -
03Nov06
1228 - 4320 Tractor - 06Apr10
1229 - 4620 Tractor - 06Apr10
1236 - 7020 Tractor - 04Nov09
1239 - 500C Backhoe Loader -
07Nov06
1240 - 510 Backhoe Loader -
29Aug06
1241 - JD301 Tractor - 03Nov06
1242 - JD401 Tractor - 11Dec08
1256 - 440, 440A and 440B Log
Skidders - 29Aug06
1289 - 2030 Tractor - 06Apr10
1290 - 6030 Tractor - 20Jun08
1291 - 7520 Tractor - 02May08
1293 - 4030 Tractor - 06Apr10
1294 - 4230 Tractor - 06Apr10
1295 - 4430 Tractor - 06Apr10
1296 - 4630 Tractor - 06Apr10
1297 - JD740 Skidder - 03Nov06
1401 - 2630 Tractor - 06Apr10
1403 - 544B Loader - 18Jan11
1404 - 644B Loader - 18Jan11
1419 - JD740 Grapple Skidder -
06Nov06
1428 - 300B Loader and Backhoe
Loader - 26Mar08
1429 - 301A Tractor and Loader -
03Nov06
1430 - 401B Tractor and Loader -
03Nov06
1431 - 401C Loader and Backhoe
Loader - 19Jul05
1432 - 302 Tractor and Loader -
06Nov06
1433 - 302A Loader and Backhoe
Loader - 16Jun06
1481 - 646 and 646B Compactors -
06Nov06
1485 - 8430 Tractor (1974-1981) -
04May09
1486 - 8630 Tractor - 04May09
1504 - 770 and 770 (Automatic
Blade Control System) Motor Graders - 29Aug06
1518 - 640 Log Skidder and Grapple
Log Skidder - 30Aug06
1519 - 670 and 670 (Automatic
Blade Control System) Graders - 06Nov06
1520 - 762 Elevating Scraper -
21Oct08
1523 - 440C Log Skidder and
Grapple Log Skidder - 05May06
1524 - 540B Log Skidder and
1538 - 2440 ( -340999) Tractor -
06Apr10
1539 - 2640 (s.n.-340,999) Tractor
- 06Apr10
1571 - 743 Tree Harvester and
Feller-Buncher - 21Oct08
1583 - 444 Loader - 06Nov06
1620 - 670A, 672A, and 670A, 672A
(Automatic Blade Control System) Graders - 24Apr08
1621 - 770A/770AH and 772A/772AH
(Automatic Blade Control System) Mo tor Graders -
06May10
1716 - 862 Elevating Scraper -
21Oct08
1725 - 740A Log Skidder and
Grapple Log Skidder - 21Oct08
1760 - 2440 (341000- ) Tractor -
06Apr10
1761 - 2640 (s.n. 341,000- )
Tractor - 06Apr10
1762 - 2940 Tractor - 06Apr10 ( FR
DE )
1763 - 2040 Utility Tractor
(350000- ) - 06Apr10
1764 - 2240 (350000- ) Tractor -
07Apr10
1788 - 444C and 444CH Loader -
06Nov06
1789 - 544C Loader - 06Nov06
1790 - 644C Loader - 06Nov06
1791 - 646C Compactor - 06Nov06
1792 - 743A Tree Harvester and
1793 - 762A Elevating Scraper -
21Oct08
1874 - 8850 Tractor - 08Apr09
1875 - 8450, 8650 Tractors -
30Dec09
1898 - 4040, 4240 and 4440
Tractors (North American Edition) - 03May10 ( FR
DE )
1899 - 4640 and 4840 Tractors -
06Apr10
1901 - 4050, 4250 and 4450
Tractors - 01Jun10 ( FR DE )
1902 - 4650 and 4850 Tractors -
07Oct09 ( FR DE )
1903 - 8440 and 8640 Tractors -
04May09
1930 - 310A, 310B Backhoe Loaders
- 16Jun06
2028 - Radial Piston Pumps -
30Aug01
2224 - 8560, 8760, 8960 Tractors
(North American Edition) - 11Aug09
2249 - 4055, 4255 and 4455
Tractors (North American Edition) - 01Jun10 ( FR
DE IT ES SV )
2270 - 4555, 4755, 4955 Tractors
(North American Edition) - 01Feb10 ( FR DE IT ES
SV )
2334 - 4560, 4760 and 4960
Tractors - 30Dec09 ( FR DE IT ES SV )
2372 - 8570, 8770, 8870 and 8970
Tractors - 07Jul10 ( FR ES )
4107 - 3120 Tractor - 01Aug06 ( FR
DE IT ES SV )
4127 - TRACTOR 3030,3130 - 17Apr02
( FR DE IT ES SV )
4133 - 1530 Tractor - 27May08
4140 - HYDROSTATIC FRONT WHEEL
DRIVE FOR 2130,3030,3130 TRACTORS - 30Aug01 ( FR
DE IT ES SV )
4143 - 1830, 2030, 2130 Tractors -
01Aug06 ( FR DE IT ES SV )
4150 - 2040 Utility Tractor ( -
349999) - 27May08
4151 - 2240 ( -349999) Tractor -
27May08
4152 - 1020, 1120 Tractors -
16Mar06 ( FR DE IT ES SV )
4154 - 830, 930 Tractors (European
Edition) - 05Apr06 ( FR DE IT ES SV )
4155 - 1030, 1130, 1630 Tractors -
01May06 ( FR DE IT ES SV )
4160 - 2840 Tractor - 04May10
4164 - 2020, 2120 Tractors
(European Edition) - 17Apr02 ( FR DE IT ES SV )
4165 - 4040, 4240, 4440 Tractors
(European Edition) - 30Aug01 ( FR DE IT ES SV )
4173 - 1640, 1840, 2040 Tractors (
-429999) European Edition - 21Jul10 ( FR DE IT ES
SV )
4174 - 2040S, 2140 Tractors ( -
SV )
4175 - 3040, 3140 Tractors ( -
SV )
4183 - 4040S, 4240S Tractors -
01Aug06 ( DE IT ES SV )
4184 - 1640, 2040, 2040S Tractors
(430000- ) - 21Jul10 ( FR DE IT ES SV )
4185 - 2140 Tractor (430000- ) -
4186 - 3040, 3140 Tractors
4187 - 2350 and 2550 Tractors
(North American Edition) - 16Jul10
4188 - 2750 Tractor (North
4189 - 2950 Tractor (North
(quoted from post at 21:09:29 02/23/11) Thankyou Txjim. For speeding time on a computer,
while.
Your welcome.
I'll bet you could really "thrill her" if you'd "start & finish" her kitchen remodeling!!!!!!!!!!!!!!!!!
Then she might allow you to buy a new JD MFWD tractor.
