1030 Fuel Tank
WHess
Took tank off to clean suspected crud out.Did"nt find any crud,but have a loose baffle laying on tank bottom.What"s the best fix?
doubtful if there is a workable fix ,,can t get it out either/ can you ???... just thinking... what if you put a aired up innner tube in the tank for a splash baffle ???
Thanks for the response J.No,only way I know to get it out is to cut the tank.Will probably try sweating a length of copper, with cross drilled holes, into brass fitting in bottom.This should keep baffle from restricting flow.Thanks again!
