1066 tellight
When the light comes on (when you push in the clutch) it means that the hydraulic pressure has been released from the torque amplifier allowing you to shift the tractor. If you ever need to adjust the clutch linkage its very important that you adjust the small linkage on the dump valve that is connected to the cluch linkage. If it is out of adjustment it will be obvious because the tractor won"t shift very well
