1100 Massey shifting
C. Burnett
I'm going to look at a 1100 MF tractor that the owner says he has owned for the past 25 years and it has always had a little bit of grinding, for lack of a better term, when he shifts from one gear to another. I used to run a 1100 about 35 years ago but I can't remember how it shifted. I want to think there is a method of shifting that reduces this problem somewhat but I can't remember. What is the actual problem that causes this and can it be solved. The tractor supposedly is in excellent condition with new tires and Westendorf loader, kept in the dry and priced at $9500 obo.
Multipower in high range provides engine braking. Low range does not. I get a lot of gear clash if I try shifting from neutral to any gear if Multipower is in low. It takes a while for the gears to spool down.
I ran an 1100 back in the 80's. If there's a way around that slight grinding, we never found it.
Just considered it the nature of the beast. Still my all time favorite tractor of those I spent time on.
