12 volt coil
grandpa Love
This says it's a 12 volt coil. It doesn't say" no external resistor needed". Is this what I need on my Oliver 77? It has a non working 6 volt generator and a 12 volt negative ground battery. I assume the coil on it it a 6 volt. No writing on it at all.
Use your digital meter!
Set the dial on a low ohm setting. Check across the + and - terminals.
If it's around 1.5 ohms, it needs a resistor.
If around 3 ohms, it does not need a resistor.
Always a good idea to check regardless what the box says.
Ohms is the little like horseshoe looking symbol on the lower left of the picture. Do not use ohms on voltage or you will need a new meter. The smoke will get out.
Set it on ohms, you are measuring resistance, not voltage or amperage.
Turn your multimeter dial to the lowest ohms setting, usually 20 or 200.
Me I'd go with the coil plainly marked "no resister needed". That's what I use on my 12 VOLT conversions. Eliminating a resister which is just one less thing to go wrong over time.
Rick
Set the pointer to the 6:00 position, 200 OHM.
The polarity of the leads doesn't matter.
Hold the leads by the insulated part, don't touch the probes or terminals while taking the reading.
Use solid, steady pressure against the terminals, wait for the reading to stabilize.
The reason I suggest checking regardless of what the box says, there is a lot of confusion about coils. It could have been sold and returned in the wrong box. Many times auto supplies change suppliers and old stock is reboxed,anything is possible. Unless the information is printed directly on the coil can, anything is possible. Don't trust the box.
Grandpa, the way to determine if the coil is a 6 volt or 12 volt are as follows:
Use the Ohm Meter function on a meter set to the lowest ohms RESISTANCE range (may be like 20 or 200 etc depends on meter), that's NOT the DC Volts range, and attach the leads to the two small + and - terminals. If it reads in the 1.2 to under 2 ohms range (1.5 typical) ITS A 6 VOLT COIL and if used on a 12 volt tractor you need to add an external series in line voltage dropping (12 down to 6) ballast resistor.
If it reads more like 2.5 to 4 or so ohms (3 typical) ITS A 12 VOLT COIL and no ballast is used on a 12 volt tractor
A coil labeled "12 Volts" or "12 Volts NOT for use with ballast" is likely a full true 12 volt coil no ballast needed
HOWEVER if it says 6 volts or says 12 volts for use with ballast ITS A 6 VOLT COIL
NOTE wire coil at correct polarity
For a NEG ground tractor the coils + receives voltage from ignition switch and - wires to distributor
For a POS ground tractor the coils - receives voltage from ignition switch and + wires to distributor
Hope this helps post back any questions
John T
Grandpa Love,
I've found your ohmmeter is typically a conductivity tester and not an accurate ohmmeter. If you touch both leads together good change you won't get zero ohms. Unlike the old analog ohmmeters you can't adjust the zero. So your ohmmeter will give you a ball park reading.
The old rule of thumb, primary current is 4 amps. So if you moved the positive lead to the 10 amp hole. Move the rotary switch to 10 a. Connect the negative lead of the meter to the negative of the battery, the positive lead to the negative of coil. Connect the + of coil to + of 12v battery and you should get 4 amps. If you get 8 amps, you need a ballast resistor.
My Jubilee has a 6v coil and a ballast resistor. The resistor uses 6v, the coil uses 6v and 4 amps.
A 12v coil should use 4 amps without a ballast resistor.
Ammeters are used in series with the coil.
Good luck.
George
Son,who works at O'Riley's,
ordered this one last night.
<img
src="https://www.yesterdaystractors.com/cvphotos/cvphoto20358.png">
<img
src="https://www.yesterdaystractors.com/cvphotos/cvphoto20359.png">
<img
src="https://www.yesterdaystractors.com/cvphotos/cvphoto20360.png">
Says it crossed referenced with
this Napa coil
Grandpa, from what you showed and stated BOTH coils appear to be full true 12 volt rated units WITHOUT BALLAST
THEREFORE on a 12 volt tractor you DO NOT add any other ballast resistors.
To double check stick your ohm meter on the low ohms resistance scales (20 or 200) NOT DC Volts across the two small terminals and it should read somewhere in the 2.5 to 3.5 ohms (typical 3 ohms) range.
For NEG ground the ignition switch wires to the + and - wires to distributor
John T
John T, thanks for posting this coil testing info, going to print it out and stick in the front of my Motors manual for a handy quick reference. Thanks again, Mike
