12 volt conversion
tomturkey
To all: A question for you all. I've always just followed some ones posted wiring diagraph and it has always worked. I've always placed a resister between the coil and the distributor. my understanding was that it knocked down the voltage/amperage?? going into the existing 6 volt distributor. If that is the case does one need a 12 volt coil in the conversion, and if you use the existing 6volt coil do you need a resistor. Any explanation needs to be simple and straight forward as electrical stuff is not in my wheel house. Like I said, I've always just followed the directions and used whatever the diagraph called for. Thanks, I hope to say good by to my last 6 volt battery. Please don't chastise me for converting, I'm done with 6 volt generators regulators and batteries. gobble
(quoted from post at 17:30:48 08/16/23) To all: A question for you all. I've always just followed some ones posted wiring diagraph and it has always worked. I've always placed a resister between the coil and the distributor. my understanding was that it knocked down the voltage/amperage?? going into the existing 6 volt distributor. If that is the case does one need a 12 volt coil in the conversion, and if you use the existing 6volt coil do you need a resistor. Any explanation needs to be simple and straight forward as electrical stuff is not in my wheel house. Like I said, I've always just followed the directions and used whatever the diagraph called for. Thanks, I hope to say good by to my last 6 volt battery. Please don't chastise me for converting, I'm done with 6 volt generators regulators and batteries. gobble
f you use an honest 12v coil, no resistor needed.. Resistor needed to reduce coil current if 6v coil needed. Not real likely that you saw diagram with resistor between coil and distributor. The correct placement is between ignition switch and coil. Between coils & distributor will run, but spark is likely reduced a bit. Observe polarity markings on coil (+/-) for same reason, i.e., slight reduction in spark, but will run.
Jessie,
If you don't get the right size ballast your
points won't last and the nightmare begins.
I recommend buying a 12v coil. The price for a
ballast and 12v coil are about the same.
There are different size ballasts sold for a 12v
conversion.
i won't chastise you for it, i'll compliment you. good move :)
i only have 2 tractors. converting it to 12 volts was the first thing i did with one of them. the other had already been converted by a PO.
JMOR, I just checked my diagraph from my files and you are absolutely correct, resistor between ign switch and coil. you are also correct that it will run with
the resistor between the coil and the distributor as I have two tractors set up that way. My dyslexia must have been kicking in and I just copied what I had on
another tractor. What is the resistor doing to the voltage from the ign to the coil? My misunderstanding is that the points and condenser were set up for 6
volts, so as not to burn up points or condensers we used the resistor. Like I said my misunderstanding. If its been awhile for me sometimes I must go back to
the beginning to understand what I am doing, and its been awhile. thanks for you help. gobble
Hi Tom, your good question:
its been answered before by myself and others so I will just give you some basics, SIMPLE AND STRAIGHT FORWARD AS YOU ASKED and ONLY to your question
If its a 12 volt tractor you can use EITHER A) A full true 12 volt rated coil NO BALLAST REQUIRED orrrrrrrrrr B) The old 6 volt coil PLUS an inline series voltage dropping (12 down to 6) Ballast Resistor placed between the ignition switch output and coils input (NOT elsewhere is my choice) .. That way it drops 6 volts leaving 6 volts for a 6 volt coil EASY PEASEY works either way.
NOTE match the coil polarity to that of the tractor.
Hey this YOUR tractor YOUR money YOUR choice you get no argument from me
Post back any more questions, I purposely DID NOT talk about things you didn't ask.
John T
The resistor is decreasing the voltage to the coil. The goal is to get the voltage at the 6V coil to be approximately half of the 12 volts of the battery. This depends on what the DC resistance is of the coil. As Geo mentioned, the ohms value of the resistor is important as well as the wattage rating. Sorry if I'm getting too deep with this. I won't go any deeper.
John T; thanks for sharing, seems there is no end to questions pertaining to electricity. your always willing to help with no negativity. your a good man. thanks tom
Good luck finding a ballast with the same resistance as the coil. That's why I recommend buying a 12v coil.
You need an ohmmeter to accurately measure the resistance of the coil and the ballast. They must be the same resistance.
12 volt battery and no resister and 12 volt converted coil/distributor.
Or
12 volt battery, a resister, and coil/distributor left as 6v.
I put resister between kill switch and coil.
If you leave distributor as 6v, and go to negative ground 12v battery, hook wires up accordingly on coil. Which basically means switch them around. Coil terminals should specify + and - . So naturally wires need to be swapped there if you change grounds of the system.
If he just buys a resistor for an old Chrysler product from the 60's it will work just fine and is already set up for the job. No fooling around with OHM meters for it.
The coil we use on 12 volt conversion is written on the barn wall....
tom, in a simple DC circuit the location of the resistor doesn't matter. It achieves the same result.
Also, distributors are voltage-agnostic. There is nothing you need to do to the distributor itself to "convert" from 6V to 12V. The wire from the coil to the distributor is just so the distributor can "ground" the coil through the points, completing the circuit and causing it to charge for the next spark.
This post was edited by BarnyardEngineering on 08/17/2023 at 06:21 am.
Here is a diagram that may help you better understand the question.
The points and the coil do not care if circuit is fed from a 6 or 12 volt battery. The points and coil want a near constant AMPS (usually about 4 amps).
Ohms law states that the current equals voltage divided by resistance.
6 volt coils are about 1 1/2 ohm resistance across primary, direct 12 /volt no resistor required coils are about 3 ohms.
In a 6 volt system 6 volts divided by 1 1/2 ohms equals 4 amps.
If you double the voltage to 12 volts you will need to double the resistance to 3 ohms to maintain the 4 amps. This can be done by adding a 1 1/2 ohm resistor or changing to a 3 ohm coil.
These voltage, current, and resistance values are nominal and will vary slightly in real life.
The 3 ohm direct 12 volt coil has the internal resistance determined by type of wire and number of turns in the coil. It does not have a separate resistor in series with the winding inside the coil can.
Jessie, it would be interesting to see another scope screenshot showing how the coil/condenser oscillation area of the sparkline (C-D) is affected if the resistor is (incorrectly) installed between the coil and condenser/breaker points.
I need to find time to do that!
Wore out and Jessie, I looked but cant find it now I will try again later. The
article its tests and results showed why the ballast resistor should be placed BETWEEN
IGNITION SWITCH AND THE COILS INPUT. If I find it I will let yall know, seems like it
had to do in part with the coils ringing and coil/condensor current as the condensor
discharged and recharged BUT I FORGET no warranty lol
John T still ever curious yet retired EE
(quoted from post at 11:53:42 08/17/23) Wore out and Jessie, I looked but cant find it now I will try again later. The
would like to see it. I had a distributor set up on bench driven by a variable speed motor and did many experiments with different coils and different connection configurations and concluded that placement may matter theoretically , but not in actuality (resulting spark).
