Although most prefer the alternator, its possible and easier to just convert using a 12 volt generator you know (or have a shop convert yours to 12 volt), that saves having to swap polarity,,,,,,,,reversing coil and ammeter leads (if youre at Pos ground now),,,,,,,,,and all the brackets n alternator mounting stuff........
A new or used or rebuilt 12 volt genny should fit right in NO MODS NECESSARY and you need a 12 volt Voltage Regulator of course,,,,,,,,add a series external voltage dropping (12 to 6) Ballast Resistor after the ignition switch ahead of before the coil,,,,,,,a 12 volt battery (DUH),,,,,,,,,polarize the genny,,,,,YOURE OFF TO THE RACES
If you install an alternator at negative ground and youre now at Pos ground??? Swap ammeter leads,,,,,,,,,swap ignition coil leads,,,,,,add the ballast,,,,,,,,,go racing. If you need my canned generic alternator wiring instructions, post back
John T
