weirdbeard
I was going to convert my 49 8n to 12 volts and was wondering if anyone had any suggestions on which kit to get. Also has anyone had their generator rewound to 12 volts. Thanks for any advice.
f you can weld a little or have a friend that can help with really simple brackets, you can put a "kit" together your self and save about $100. There isn't much to it.(quoted from post at 20:56:40 12/21/09) I was going to convert my 49 8n to 12 volts and was wondering if anyone had any suggestions on which kit to get. Also has anyone had their generator rewound to 12 volts. Thanks for any advice.
(quoted from post at 02:38:44 12/22/09) Read up on the conversion here. David.....................
http://home.earthlink.net/~8ntractor/12volt.html#wire
ep, Hobo, that's why they use crimps in airplane wiring. I didn't read that on the internet, I did 'em.(quoted from post at 23:08:31 12/21/09)(quoted from post at 02:38:44 12/22/09) Read up on the conversion here. David.....................
I am not sure what so many folks are sold on a solider connection,,, its probably only needed at the bat terminal at the alt and amp meter...
A soldered connection is more prone to failer than a crimped connection,,, when you solder a connector it weakens the joint were the wire enters the connector,,, it can not Handel vibration it will break (you just made it ridged) were as a crimped connection will flex and not damage the connection...
Its been repeated so much folks believe it,, its a fell good issue that will cause more trouble than its worth...
WARNING :shock: all I know I read on the Internet,,, do it enuff and you can become a guru also,,, not responsible for damages,,, I read it and just pass it along,,, proceed with caution
never have & hope I don't. This one flew a little bit:(quoted from post at 00:11:31 12/22/09) When waz the last time yall flew an 8N?
:shock:
(quoted from post at 21:14:33 12/21/09)never have & hope I don't. This one flew a little bit:(quoted from post at 00:11:31 12/22/09) When waz the last time yall flew an 8N?
:shock:
(quoted from post at 04:26:43 12/22/09)(quoted from post at 23:08:31 12/21/09)(quoted from post at 02:38:44 12/22/09) Read up on the conversion here. David.....................
Hobo!!
This time you need to do some Internet research.
I don't think I have ever seen you be this far off base.
(quoted from post at 08:39:00 12/22/09)(quoted from post at 04:26:43 12/22/09)(quoted from post at 23:08:31 12/21/09)(quoted from post at 02:38:44 12/22/09) Read up on the conversion here. David.....................
Hobo!!
Ok Big Boy show me the Factor recommend repair procedure rite out of the repair manual,,, take yer pick from any of the big 3 are a tractor manual.
I only read this chit never have any hands on experience like Y'all boys,,, not a highly trained killer by uncle sam's army,,, but would like to have a licence to drive a nuclear submarine...
(quoted from post at 10:45:03 12/22/09)
Is this a required question to get a nuke submarine drivers licence...
If it makes any difference I have been know to break the best set,,, Chinese are merican made it did not make a difference...
Course I do expect folks would use the correct connector with the correct gauge wire,,, its possible to weld a rats arse shut if you can keep'em still long enff for the operation,,, its also possible to weld a crack shut as long as you can jump across it ,,, is it the right way dunno will let you figger that out (what Bud's are for)
ommy, you said a mouth full there! I'll pick work on an N or any multi-cylinder with a carb over weed eater engine work any day!(quoted from post at 13:35:41 12/22/09) I have bought several from Dennis Carpenter and they have worked very well. I've never put a one wire unit on that wouldn't charge at idle. Not sure why thats a problem. These Ns are less complicated than a weedeater; sometimes we just think about stuff too much!
