12 volt conversions
Anonymous-0
Can i convert my 6 volt 8N ford tractor to 12 volts with out changing head lights or the other light bulbs now existing?? Any response will be greatly appreciated. Thanks Stan.
You COULD by using a voltage reducer or connecting them in series.
To do it properly with a voltage reducer that will hold the voltage constant under varying load is $$$$.
Connecting the lamps in series is a pain in the a s s, and you would loose BOTH headlamps if one burns out.
So, WHY not just replace the bulbs with 12 Volt units... NOT high-dollar items, if you shop around.
Mine lasted when I converted from 6 to 12 about 10 seconds. Just, as stated above , buy new lamps, no big, expensive deal.
Just what all are you changing exactly? Headlamps are some of the cheapest and easiest parts of a conversion yet you are holding back???
my alt. guy sells a reducer to a guy around here that fixes and sells 8 and 9N tractors he likes to keep them as orig. as possible and puts a 12V alt on them to make them reliable in the elec. department...
I don't know a lot about electronics. Wiring head lights in series does blow my mind of why you still wouldn't have 12v to them. Remember the old Christmas lights wired in series? One go out and you had to check every bulb till you found the burned out one? Well would that mean on those Christmas lights, if you had a string of 12, would that mean you had only 9V to the bulbs? OR if the bulbs are like a resistor, wouldn't each bulb down the series have less voltage than the one before it? If so wouldn't each along the string be dimmer?
Simple answer is NO. Ya you can do the reducer thing but it would cost you 3 or 4 times what the bulbs would. So if your going to switch it to 12 volts bite the bullet and spend another $10 or so for the bulb and be done with it. Cost all total should be less then $100 if you do the work your self and know the right places to buy the stuff. Alternator around $35 wires another $10 battery $35-50 so even with new bulbs you can do it for less then $100
Hobby farm
If the lamps in series are IDENTICAL, each and every one in the series circuit has the same number of AMPS flowing though them, and the same Volts dropped across them, so each is heated by the same number of WATTS, so they will be (more or less) of equal brightness.
A simple fixed resistive "reducer" is just fine, if sized to the load. HOWEVER if the load changes (one bulb fails, for example) current through the dropping resistor will fall, and voltage to the remaining lamps will INCREASE, potentially burning them ALL out, one at a time.
That's why a simple dropping resistor would NOT be a good idea.
don't know what kind or what specs are but Mr. Railey has never lead me wrong b4. He has also helped me on other elec. problems and was glad to help at no charge for info only if he had to work (labor) he gets a premium. I am sure you know what you are talking about as I have read much of the advise you have given over the years. I will try to ask him what he sells to the Ford N guy and let you know so you can give advise on the specifics.
yea sorry bout that i had other stuff on my mind i was thinkin bout guages for my jeep J20 but yea there all mechanical guages i forgot!! you still have to change the dash light then
Yes. Wire the headlights in series. It's not all that practical. It probably won't work all that well. You'll have a mess of wire... but it can be done.
Just change the lights out to 12V units. I believe they're not that hard to find.
Rod
