12 VOLT POINTS CONDENSER
DANA BIZZELL
I am wanting to swap distributors on my 140s, one is 12 volt and am wanting to move it to 6 volt system. Question will I have to change points and condenser in
both, Reason for swapping the six volt distributor is not IH and you have to remove distributor to set point, they are not two piece points.
So what system do you have currently on the rest of the tractor?
Does it have a 6 volt or 12 volt battery?
If I'm getting this correct, you want to convert your whole tractor over from 12 volt back to 6 volt? Or do you just only want to change the coil to a 6 volt coil?
