1200 oil pan
11
Could someone tell me if the oil pan on a 1200tk can be removed without lifting the engine or removing any steering parts, it looks like there is room but im not sure if it will clear the oil pump.
Ben
i dont think it can be done without lifting away from front axle. I have case workshop manual in the barn. I will try to verify for you. I dont think you can clear the pick up tube
You will need to take front axel mount bolts loose and raise the front of the tractor from the axel to get enough room to remove the oil pan.If i remember right it take about four inches.
