Friend has an early 1256 with 10,000 hrs that was bought from the original owner. The tractor was a dealer demonstrater for the first 300 hours, and had the C4 block update before being sold to the original owner. Tractor starts and runs great, has good power but has a tick higher up on the engine around the injectors. Figured we would send in the pump and injectors as they are original to the tractor (previous owner said he never had any engine work done all the years he owned it). Turned engine to get the injection pump timing marks to line up and noticed that the flywheel is at 15 degrees. The book says timing should be at 6 degrees. Did IH do somthing to the pump for the demonstrater 1256's? Thanks!
