135 fuel gauge installation ?
ampster63
I am installing a new fuel gauge; on the back of the fuel gauge there is 3 wire clips. One has a "B" beside it, one has a "T" beside it and the other has "12 v" beside it. How would I wire this to get it working properly assuming the sending unit is good?
Hi,
Here is a picture of the setup on a UK 100 series tractor.
Black - earth
Brown and blue - from the sender
Brown and yellow - from the dynamo
Hope it helps
DavidP, South Wales
Good luck that it works. I had the same problem with my 135 so decided to replace the complete unit, gauge and sending unit. I got mine at our O'Reilly's store it looks just like the Masseys. The sending unit plate fits the tank perfect and everything works great. The unit was for a GM vehicle. If you need to replace your consider this. If you need the exact part number let me know.
Hi, for the UK;
Fuel gauge 894844M1
Sender 1825031M91 Fixed arm 165mm,float arm 220mm, movement of float 290mm, 6 holes
Sender 908600M1 A above 100mm, 160mm, 220mm,
5 holes
DavidP, South Wales
