135 Hydraulic troubles
TexasRed
Hello friends I am new to the site, But I also knew this would be the place to consult the real experts. Got a 69 model 135 from this guy and the tracor had been through a flood. right after the water went down the tractor went to the shop. All was fine with the tractor except the hydraulic system was not correct after the flood. All the rest of the tractor was OK. He let the tractor sit for 2 years and that's when I came along. Before starting the tractor I changed all the fluids, filters etc... The hydraulic system at first would lift a box blade 4 inchs off the ground then set there and pluse up and down a little. After several hours run time I looked down in the transmission fill hole and the fluid was sightly milky. Out came the fluid and was changed again. The lift is even slower that before and will not lift the box blade or nothing. it will come all the way up with no load after 1-2 minutes. I am waitng for service manuals but is there some kind of system filter that I am missing somewhere???
Please advise.
Gary in Texas
There is a hydraulic filter on top the hydraulic pump. Just inside the hole where the PTO shifter mounts on a round plate. Raise the left rear wheel about 8" and oil won't run out with that plate off.
Be sure to engage the shift yoke back on the PTO gear when you put that cover back.
Its possible valves or controls have rusted from all that water.
Gerald J.
Thanks Gerald,
I will get in there to that Filter. I am not sure if it unscrews or what happens there but I will figure it out. Thanks a million for the responce.
Gary
Hello,
I agree with Gerald. Any water presence in the system has potential to cause big problems.
Rust will soon form on the control valve and in places like the poppet valve stems where the slightest sticking can cause a system failure or at least slow response.
DavidP
YOU NEED AN OWNER'S MANUAL!
The filter is between two cups with a winged screw down the middle. You MUST lift the cups out with the filter, else you will dump grunge into the pump. Often the winged screw has a wire tie to be sure it doesn't come loose.
Gerald J.
Hey Gerald I got my owners manual in and looked up the filter on the hydraulic pump thanks for you help .
Texas Red
Also, care should be used when re-installing same as the threaded bolt can be incorrectly installed thru the intake holes instead of the center hole causing a no seal condition which will bypass the filter. A not good deal. I found this out the hard way.
gd
