135 power sreering question
in sticks
on a 135 continetial gas that has the power steering valve sort of built around the steering shaft.the hyd lines are attached to the valve with ''banjo bolts'' two bolts are brass and the other two are steel. question is which go where?ase the bolts and banjos are interchangeable from side.this was in pieces when i bought tractor so any info is much appreciated. thanks
According to my parts book on US made MF-135, the bolts are differnent threads. Left side is 5/8" the right side and cylinder is 9/16" so they have to go only the right places. No mention whether brass or steel. The banjos are different sizes, but the O-rings are all the same. You would do good to put new O-rings all over.
Gerald J.
