135 remote hyd
Anonymous-0
I saw a pic of a 135 remote hyd valve bodyne time on this web site
single spool if someone have information let me know
http://search.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=mf&th=143555
This may be what you are asking for. It is NOT a remote setup but a diverter setup. For a remote system you will need a aux pump which runs off the same drive system for the lift pump inside the belly of the beast.
I can look up the valve info if you want, let me know.
I have an original single spool valve I took off my MF-135. It replaces that little cover under the front center of the seat. The lever sticks up between your legs. It works great - however: it will only push fluid to the new cylinder after the 3-point is at the top. I replaced it with a block in that same place that diverts the fluid to a separate single-spool valve. Now, with the hydraulic set on "Constant Pumping" everything works all the time. If you are interested, let me know.
