1350 rearend
Anonymous-0
I am wondering how much shorter a G 1350 rearend is compared to a G 1355 with the hydra power. If it is significantly shorter I am looking for one in good condition
A g-1355 rear would be lighter due to the axle housings being significantly smaller. ABout being shorter, the hydra power or an over/under would probably add length unless you weren't to put one in. Our 2-150(G-1355) White and 2155
(G-1350)oliver are about equal in length. I would have to measure to find out, but I bet the 2-150 is longer by a little
Thanks,I thought I could make it shorter and get a little more weight transfered to the rearend since I'm having trouble getting it hooked to the ground. What about a g 1000 ?
