Was in a hurry after mowing out some fields and rushed the gear change while parking. Tractor is now stuck in neutral. I've seen a lot of posts about stuck in gear and have tried gently moving gears with a large screwdriver without success. When I try to move the gear lever back or forward (left or right position) it only moves about 1/2 cm.
This has happened twice before and I've managed to get it working again. I know his sort of thing usually just get's worse until it has to be fixed permanently, but with hay time approaching a quick fix would be handy.
Also any info about how much work the proper fix is would be helpful.
Mike.
Mike.
