When A Turbocharger goes bad does it blow oil between the Exhaust Elbow and the Turbocharger.
My 1370 was setting and running just fine. Next thing i have oil coming from the area between the turbocharger and Exhaust elbow.
This is not a normal oil leak from a worn engine. The amount of oil is as if an oil line is spewing oil.
I had the oil line off the turbo charger while i was doing other things to the tractor. I put new rubber sealing rings on the line.
Do any of you have a suggestion on how I can verify it is the Turbocharger leaking.
