1420 / 2 speed rotor issue
AJinPa
The Hi/Lo speed for the rotor will not come out of Hi. I have shut it all down many times and retried like the manual says but it is still stuck in Hi. I can't even get it to the neutral position. It was working fine when I went from oats to beans.Is there anything else I can try? I am shelling ear corn out of the crib and it needs slowed down. Thanks for any helpful tips.
If you can't rock the rotor drive pulley and get it to move, look up under the pulley on the rotor gearbox itself which may require a mirror and see if there is anything that could be wedging the lever. If nothing is there then the problem is inside the gearbox.
Don't know about a 1420 but have a 1480 with a similar problem. We always use two individuals. One on the ground moving the lever and the other inside the engine compartment giving the linkage near the gear box some extra force. A pain but it works. We don't need to change that often so haven't further investigated. Suspect the original owner had some difficulty changing it, applied too much force from the ground access handle and mucked it up.
Thanks Guys. Like you said James, really only need to move it a couple times a year and didn't want to get too involved. I did get two loads of ear corn shelled today, I slowed the egine rpms down to 600 and took my time feeding it. It did a very nice job. IHman, I hope you're not right, but the way my luck can go, I may have an issue in the gear box its self. I have the linkage removed and I'm able to tap on the plunger with a hammer. You would think that by rocking the rotor by hand it would even try to go, but nothing. I'll just keep tinkering with it. Thanks again guys.
That should shift real easy when you rock it back and forth. Check the oil level in the gear box, if it's low then you probably have a galded shaft where the collar slides to shift it from low to high range. The fill/drain hose leaking isn't unheard of, we fixed ours last fall the clamp that holds it to the fitting on the gearbox is a real pain to get to.
I changed the 2 speed rotor g/b in my 1680 last year. Hopefully you don"t get to that point, because is isn"t particularly cheap or easy.... but if you do, ask on here, or search for my old post on this forum.
Chris
