1466 for puller
larryanderson
I am looking at a blackstripe 1466 open station.Our fair has a pull and was wondering if this would make be a good choice.How much power is available and still be considered stock.The 1066s seem to be popular.The class weighs 10,000. Its basically for fun but it takes at least 250HP to be competitive probably more
If they don"t let you put pressed steel on the rear, I don"t think you can get it down to 10,000.
You got that right The Fuel Pumps Have No way of Delivering Enought Fuel! there was a guy who Claimed by TURNING UP THE PUMP THEY WERE Making high HP out of 1370's [450 hp with out Blowing the trans and rear end ??? ] a while back,He Sure Didnt know What he Was Claiming WAS Impossable, with out Major Internal Machine Shop Work,and Fuel System make over.There most be a lot of FUNNY DYNOS OUT THERE that give false readings.I VERY Good Friend of Mine Builds SUPPER Stock Road Tractors,Peterbuilt,KW's These have 12-71's Set up with 4 Turbos, Auto Trans,There are a lot of Extra's These Dreamers have no idea of to get the Power they Claim.If it had that much as Claimed there would be BIG HOLE OUT BOTH SIDES OF THE BLOCK !! THE RODS WONT TAKE IT .
I was not going to reply to this thread, but here we go...
The stock IH rods will hold around 2500hp if they are heat treated, around 1800 without.
A stock IH 400 series engine,i.e.(414,436 or 466),will hold 5000 rpm without any internal mods.
A good stock 436 will push out around 275hp TOPS without any mods other than the fuel screw, to get to numbers over 300 you will need to restrict the return and pump about 100psi fuel pressure to the pump head and bump the rpms up to around 3000.
That all being said I would have to agree that their are a bunch of guys that like to talk numbers and whatever sounds good is the story they stick by.
Been around super stock tractors for about 20 years and have had a hand in building them and watching one on the dyno.
A number is a number unless you have a piece of paper to back it up the first liar don't stand a chance.
I am a younger puller who is trying to figure some things out on my tractor and I have an IH 1256 that the pump has been maxed out on. I have wondered about restricting or closing off the return line going back into the pump, but I don't know how to go about it and do it in a way to make sure it doesn't hurt or tie up the pump. Thanks in advance for any help!
