Scott Hartzog
I am working on a 1486. My problem is when the brakes are applied the tractor comes to a complete stop in both TA and Direct. I then removed the clutch inspection cover and found the main traction clutch to be slipping badly. I then split the tractor and installed a new clutch, new pressure plate, and new flywheel. Upon test driving I found that I still had the same problem. Lube and clutch pressures test fine at 22 and 245 psi. I am fairly confident the clutch is adjusted correctly (by my IT manual) and I can see plenty of clearance between the throw-out bearing and the clutch fingers so I don't think the new traction clutch is slipping. Is it possible that the Sprague bearing and the TA clutch are bad? It just seems kind of odd to me that traction clutch, Sprague , and TA clutch would all be bad at the same time. I am not very experienced in IH tractors so any help would be appreciated. Thanks in Advance. Scott
