Robin Hood
Two questions:
The first is about the carburetor design. I am rather curious for an explanation as to why John Deere outfitted the carb with an electric fuel solenoid shut off valve. I don't profess to be a mechanic, but the idea of a solenoid valve AND a mechanical fuel pump seems to be a little bit redundant. Especially when you consider all of the other tractors out there with neither.
The tractor has been mostly sitting for the past few years, but it runs very good. The problem I have is the solenoid valve has a very small leak when the engine is shut off. Its bad enough that I have to shut of the fuel supply at the tank. Is this a leak caused by the float not closing the needle valve off, is the solenoid valve housing cracked, or is there possibly an o-ring inside that I could replace. I am told the valve is more than $200 to replace.
Second question is the weight of the wheel weights. The tractor has power shift rims (14.9-28) with 2 pairs of weights that are attached with four bolts each. I am embarrassed to say that I can barely lift one. Any idea what they might weigh?
