1550 Quick Hitch
scottjhall
I have a 1966 1550 Oliver with a 3-point quick hitch. I am wondering if anyone is experienced with this hitch as it looks like a Category 2 hitch, but the quick hitch itself has some grooves in them that look like they would accept a rounded bushing (like the ball bushing in a regular 3 point arm) instead of just a flat category 2 pin on the implement.
I have been looking for any kind of reference to how these work or if they take special pins on the implements. I don't want to just hook up a Cat 2 implement because I am afraid it will flatten these grooves out that look like they require some special bushing.
Please let me know if you know anything about these or point me in a direction to get more info.
Thank you!!
There is just a ball that goes in there. Either cat 1 or 2. I use cat 1 on the hayrake,2 on everything else. With those balls they will hook to any standard 3pt implement. I think all of mine came from John Deere. The same as the top link ball on the Deere 3pt.Probably available at places like TSC.
There are balls that go in the "jaw" of the 3pt arm. I use ones with a cat. 2 hole and use a bushing to reduce to a cat. 1 if needed. They are the same as Deere used. You can get them at Tractor Supply, Rural King, or similar type store if a dealer is not close.
I bought both Cat 1 & 2 balls from TSC thinking that, but they are too big to fit into the quick hitch. But they are really close.
Maybe the toplink ball bushing is smaller? I will have to go back to TSC and see if that is the case.
Thanks again for the help,
Scott
I made the mistake of buying some from.....drawing a blank here,they were similar to TSC and went out of business. Tsc took over most of their stores,anyway,everything was 30% off so I bought them without checking to see what they were for. They were for a Ford it turns out and were too big by just a little like you said. I'd bet that's what you have there. The Deere top link balls fit the Oliver.
I have some Cat. II balls that I am selling, that I made up myself. They hold up to abuse much better than those you get made by Speeco or from AGCO, although they do also cost a little more because I just can't make them as cheap as they can. Send me an email (left it open) if you would like any, and we can discuss price.
For Cat. I implements, you can use a bushing to reduce the bore. I plan on making some, but I can't say when yet, I've got too many other projects on my plate right now.
Donovan from Wisconsin
