rrlund
I got the 1600 in to the shop today and dropped the pan. Number 3 rod was stuck. I took one nut off of the cap and loosened the other one. It was rolled up where it was hard to get to, so I tried to roll it around and it was free. I got it turned down and took the cap off. There was just an ever so slight mark inline with the oil holes in it. I could see a little discoloration on the crank in a little band in line with the oil holes in the bearing and it felt a little rough when I ran a finger across it.
I took the bearing down to my son's shop and let him look at it. He said he couldn't believe it even stuck the engine, no worse than it looked. There's no burn marks on the inside or outside. I asked him to stop tonight and take a look at the crank and see what he thinks. I asked him if I should take some Emory cloth to it and see it it cleans up. He told me to go ahead and try it. It cleaned right up, looks good and shiny and feels smooth, but I'll let him have the last word on it. He had Brandy order another bearing. She said it's be here in the morning.
Now if I can just find a bearing for the governor. I told him to bring home a better mic and measure that too. I'm coming up with a 14mm shaft size and 31mm OD with a mechanical mic. I'll have him check with a digital since all I'm finding are bearings for 12, 13 and 15mm shaft size.
