Using my MF 165 W/multipower for mowing today and when I got in heavy grass the pto stopped turning I have came to the conclusion that it is Independent PTO as you can engage the pto without using clutch at any speed with no grinding or effort. The pto will stop as the lever is moved forward and start when it is moved back. The multipower is working great with the change in speed as the lever is moved and the braking works in high range. I checked the tran/hyd fluid at the dipstick and it was way over full I drained and put it to the proper level. Fluid was very slightly milky but not worth changing. If the trans was over full could this have caused the problem. I have not rehooked the mower to see how it works. Is there a adjustment that needs to be checked to help identify if I still have a problem. I have looked in the archives without much luck Thanks
