165 serial number
Rob Marano
I'm having trouble finding a serial number on my 165.
The numbers stamped on the transmission, engine and back-end don't correspond to any serial numbers listed.
Can someone show me where to find a serial number as I would like to replace the clutch and need a serial number to do so.
It SHOULD be on a small metal plate (approx. 2" X 3") located on the sheet metal that encloses the battery, below the steering wheel, just in front of the shifter levers. It SHOULD be there, held on by 4 small screws.
Yup, like MF Poor says, if it's there it's right on the dash panel, in front of the shifters on the bottom of the panel.
Donovan from Wisconsin
if its a gray machine the numbers will be on a plate under your right foot, on side of transmission, under brake pedal.
