1650 rear end seal
TallTom
My 1650 is leaking 80-90 right below the check plug where the lower part of the 3 point attaches.
I see the bolts to remove the lift arm but am not sure how to get to the seal. Will the outer hookup for the 3 point come off after the bolts are removed? If so is this a seal and bearing or just a oil seal?
All help appreciated.
Thanks in advance
Tom
If you are talking draft links you have to remove top cover to replace seals.not a bad job.
I may be possible to remove pto and do this repair.
Thanks for the reply, are you saying I have to remove the shaft that the lift arm is attached to replace this seal? I am not sure what this shaft does except for the anchor point for the lift arm.
Tom
That shaft is a 2 piece shaft jointed in the middle to the draft control spring. That is why you need to take the top off to seperate the shaft so you can pull it out. Your spring also has an adjustment height. Make sure you check it before you take it apart. If you do not have a shop manual get yourself one. More questions?
