Kickinbull
I haven't figured out what is causing it to run rough. I boiled the carb today. It didn't help. It will not idle. But it did when I first got it. It fires on all cylinders. Tried adjusting the distributor, it doesn't make any difference. Adjusting the carb, it doesn't help. Replaced plugs,cap rotor wires. It has electronic ignition. A while ago while having dinner the tractor was parked in lot. Heifers chewed on wires coming out of distributor. bared wires. I put elec. tape on it, but don't remember if this is when it started the problem. Is it possible that it will run, badly, with something wrong with the EI? Is there any way to test it?
