FarmerBlair
Hi,
I've been struggling with my 881 gas (6volt) in trying to get run smoothly and hoping someone here has suggestions. It didn't want to start a week ago after having sat for a couple months. It had started to run a little rough and harder to start when last used it.
-- Replaced points and plugs (AL437). Spark plugs were sooty black.
-- Replaced the rotor.
After that, engine started right up, but ran very rough.
-- using timing light, adjusted timing to 4 degrees and 24 degrees at idle and high rpm.
It still ran very rough after that. So I tried adjusting the timing by ear: rotating distributor till it smoothed out. Got it to run much smoother (still sounds off), but now it is way off on the timing. I think pretty far advanced (distributor turned counterclockwise). You can't see the timing marks on the flywheel because it is so far off.
-- adjusting the carb, but that didn't help.
-- removed the air tube between the air cleaner and carb to make sure air constriction wasn't an issue.
I noticed when I shut down the engine for a few minutes, then start it up again, it blows black smoke out the exhaust for the first second or two.
-- closed down the main fuel adjust on the carb (about 2 turns open), but it made no difference on rough running or black smoke.
-- double checked that the rotor lined up with the #1 post on the distributor when #1 cylinder is in compression stroke. Looked ok.
I'm running out of ideas why it is running rough and runs much worse when I have the timing correctly set (via timing light). Runs better (not great) when far advanced. The distributor mechanical advance seemed to be working as the timing marks shift from 4-degrees to about 24-degrees when increasing from idle to max rpm. Could there still be a distributor problem? Crossed my mind the governor could be out of adjustment for some reason, but I wouldn't have thought that would make the engine run rough like it is.
I do have a problem with the generator not charging the battery. After replacing voltage regulator a couple times, I gave up on that and just put a charger on the battery to maintain the battery at the end of the day. Been doing this since last year. I doubt that is related, but thought I'd mention it just in case.
