169 propane engine from Farmall H
BobZ
I was told that 560 pistons would fit if I take the rings out. Does anyone know for sure if this works? Thanks Bob
560 pistons have a compression height of 2.02, H-350 is 2.5 inches from the center of the pin to the top flat part of the piston. You would have to stroke it to 5 inches to bring it up to the top of the bore with the 560 piston. I have overbore kits that range from stock to up to 3-13/16 bore piston with a stock stroke for Super H thru 350. You should be able to drop in a 350 sleeve and piston kit for a 3-5/8 bore if its from a 300 (C-169) Block will be 3.75 bore with no sleeves, with a 4 inch flange counter bore left over. Hope this helps a little, but you should be able to drop in the 300-350 kit. ChadS
