Hi everyone, I have a 1755 that has something wrong with the hydraulics. The tractor steers fine and brakes work but the remotes and 3 point are slow. When hooked up to an implement it just barely will attempt to lift but I have to hold the lever forever then when I lower you can see the hoses jump and relieve the pressure. The 3 point goes up and down but comes up very slow.
I have a guage in the compensator check port and it does show the correct 2200psi wide open. Where should I look next? Thanks
