Clyde Parrish
O.k. Let me explain what I have done then someone fill me in on where I am going wrong.
I bought this 180 not running and not getting fuel to the injectors. No problem there now I get it home check it out see that there is fuel flowing from the tank. Undo some of the lines make sure the lift pump is pumping. All that is ok. I loosen the lower bleed screw and crank the engine and fuel jets out. I loosen the top fuel screw and fuel will jet out there. But still no fuel to injectors. I make sure the pump is turning and the gear is turning all is ok. So I say hey the injection pump is bad. soooooo I order a injector pump from a junkyard guaranteed to be good.
Injector pump comes in I install it. Bleed everything several times guess what? Still no fuel to the injectors. Someone tell me what am I missing. What is the chances of having 2 bad pumps. I am going to call the junkyard tommorrow. Thanks for any help. Clyde
