sam in mo
I need info. I am looking at a 180 M F. There is a Hummimg noise comeing from the transmision box. The lift raises up as soon as you start the tractor. The lift would not go down unless you killed the eng. I am thinking that I have a bad hyd. pump. If it is bad are hyd. pumps hard to come by for this tractor and do you have to break the tractor to change the hyd. pump? The tractor has a shift on the dash with high and low with 8 gears. Thanks Sam
Your tractor has multi-power, that's what the shifter on the dash is for but I thought MP was only on 6 speed transmissions? In high range the MP will make a slight noise when driving. I don't think the hyd. pump is the problem. I think it's more a linkage problem with the 3 pt. controls. David P and the other MF experts will be able to help you more. Dave
Hi both,
You are correct Dave. There are no 8-speed Multi-Power transmissions. I remember the words of the MF training instructor at the UK training school very clearly;"There isn't enough room for MP in an 8 speed box".
As to the problem it sounds more like the control valve in the pump has seized or is sticking. It is not MP so there should be no problem in removing the pump through the top. The usual procedure would be to remove the RH side cover and observe the operation (or lack of it)of the pump lever.
DavidP
Thanks for the replys. I have never been around a tractor with this trans. I looked at the owners book on it last night, also he was home this time and got to talk extensively with him about the tractor.It is a 6 speed with m. p. The power steering leaks up front on top of the steering cyc.Any thoughts on the P. S. leak or a fix. Just looking through the screen it looks like a gasket will fix the problem. The trans. pump is makeing a noise like a power steering pump on a car that is low on oil and starving for oil suply. Also when the lift will not stay down when the lever is in the down position, you have to have weight on the arms or it will go up to the top pos. I am thinking about buying it and want to think that I am not buying a lot of problems or not be able to get parts for it. I dont know when the filter was changed in the trans last. The oil looks clean and dosent smell burnt. Thanks for all the help. Have a fun and safe 4th weekend. Thanks Sam
