1800 oliver
dlauer
I have a 1800 a gas and a 1800 c diesel.When hooking up to an implement with one way cylinder, the implement slowly creeps up.This is a pita on my discmower.Any easy fixes besides adding a ball valve to shut it off entirely?BTY I have to shut tractor off to hook up hydraulic line because of some constant pressure is allways on them.Everything works as it should on my 1955 and 1755 olivers.
Your 55 series are both closed center hydraulic systems. Your 1800 A & C tractors are both open center. For the 1800A series you need to add an external bypass valve. On the C series you must use the procedure stated in the operators manual which includes loosen the bypass screw down by your right foot.The C series is going to be easier and it was me I would run the discmower with an added third valve. Send me an e-mail and I can photocopy you some stuff.
