Just did an out of frame overhaul on an 1850 Diesel. I get a vibration that rattles the hood sides between 800-900 rpm. At idle it isn't there and above 900 it goes away and runs smooth up to full throttle. I've taken out the PTO shaft and it is still there. Still get it with the clutch pedal pushed, so it must be in the motor? I thought I read somewhere about lash in the timing gears that was updated with oil pressure in the later engines. could this be the cause. I bought this tractor as a non-runner with 2 scored pistons so I am at a disadvantage of not hearing it run before. Thanks for any help guys.
