Hello when I bought this thing it had a loader with its own valves plumed into the tractor hydraulics , I removed a internal plug and it has been working OK all year, lately it has be getting slower to raise the end gate on the round baler ,the pressure is very irregular 500 psi to 1500 psi to so low the gauge won't read it all within about 30 seconds of moving the lever , now I hooked it up to my pull type swather , left lever platform, right lever reel , both plugged into the base ( front hose on each side ) base end and rod end is what book calls them . left lever pulling it back will raise the platform , right lever will raise the platform all the way up then the reel, anyone have any idea if what is going on with this thing ?? It had ATF in it when I bought it and I changed it over to thin hydraulic oil (as the manual recommended ) to be the same as my other tractors, the 3 pt works to lift round bales but is not the fastest, any ideas ??? Thanks Bryan
