Hello guys. Long story here so please bear with me,. My father has had this 530 Ck..Ive taken over ownership of this thing recently. I've found and fixed many problems on this thing. I've done a engine overhaul on it 10 years ago, I was a bit green then. I did not get the block or head checked for cracks back then....I ran this thing for many hours since the rebuild. My father got a hold of it later and pulled the thermostat..so there was no pressure in the coolant system and I always noticed it ran hot...so 2 years ago he decided to put cold water down a hot engine when the coolant ran low...bam..I ran it later and had milky oil coming out the blowby, and exhaust coming out the rad..ya it was a cracked head.. so I picked up another head..put all new gaskets, seated the valves, etc and etc..
It started no problems runs fantastic...but still gets hot..no water in coolant. So I decided to put a thermostat in it. Well firstly the coolant was flowing out the overflow...the rad cap wasn't sitting flush in the hole sealing the cap..fixed that...then started it again so the system would pressurize...it's running great..then it's starting to run a bit slower and rougher..so I shut it down...I checked a few things..then I tried starting it..it wouldn't turn over...so I thought hydrolock?... Sure enough I got more coolant/ water in the bottom end...now I'm kinda ------..so..the head is great, everything else on this thing has been fixed...
So I'm pulling the motor Maybe soon...what should I be looking for? Sleeve o rings? Cracked block?
Any suggestions on how to narrow this all down?
Phil
Phil
