1936 Huber HK
SweetLeah
I have a friend interested in restoring his Grandfather's 1936 Huber HK. I don't know a ton about tractors, but from what I am gathering this is a pretty rare tractor and this may be a long journey for us! He refuses to begin the restoration until he can find the piston sleeves for the engine. I am hoping that some of you fine fella's can help me track these parts down. I am hoping that these sleeves are either reproduced or not just specific to the only the 1936 HK. If anyone can chime in with any information that will send me down the right path to getting this project started, I will be forever grateful!
Thank you in advance!
Leah
Are there any ID tags on the engine? Listing some of the part numbers, or doing a search on part numbers found on the engine may help to ID the engine that is currently in it.
Is the tractor currently siezed? If not there are various ways of dealing with loose fitting pistons.
I don't have the answer to your first question, the tractor has been in pieces, uncared for, for 40 years. He'll have to get it to his house I suppose, before I'll be able to answer that.
I guess you could say that, the wrist pins ran into the cylinders while it was running.
Sleeves can be made for anything. Dry sleeves have been used for years to repair damaged blocks. Pistons can be made as well, it all costs money, though.
Once the engine model and make is determined the parts can be searched for.
Sweet: There's been confusion about Huber engines for a long time, partially because of confusing parts catalogs listings, such as :
(1938 Victor gaskets): "Light Four HK-HS 1934-37, 20-36 rating, Wauk CHS-CHK"...
(1936 King Products):
"Light Four HS 1930-35, Wauk CHS";
"HK 1935 32-45, rating Wauk CHK"...
These Huber listings sometimes give model designation, sometimes only ratings, sometimes both, which causes a lot of confusion (there're 20-40 and 32-45 models that used various Stearns engines, etc)(just be glad you don't have the model with the Hinkley engine!)...
If you haven't already done so (assuming no engine tag) find all the casting/stamped numbers you can and contact the Wauk Eng Hist Soc ([email protected]). They have no parts but should be able to positively ID your engine AND provide a copy of the engine manual (I don't know their manual costs--they're all volunteer so may not reply immediately).
Then you'll want to contact the Huber club--naturally I can't lay my hands on an email adds or site; will advise later if I find it.
You can search Huber here and on other sites like smokstak to find/contact other owners for advice, help or sympathy (they may try to buy yours for parts!!)...
If you get into contacting the obsolete engine parts dealers for parts there's a fair list on aths.org under "Parts and Services"; as I recall scroll way down to "engine parts". Good luck.
Here is some info on Huber Museum 220 E Fairgrounds St. Marion, OH 43302 740-389-1098 It is in the town that Huber's where made in. I think they will be able to help you. Good Luck
