1939 Allis Chalmers B block
DylanP95
Hi all,
I have a 1939 Allis Chalmers B that has a cracked block. Does anybody know where I can buy a brand new block or a used block that isn't cracked?
Where is it cracked. If between the sleeves that is common and can be used most of the time. I have a couple of blocks out of 1946 Cs that should be the same as your B
Between the sleeves on the top only is useable if the cracks aren't spread out too wide. Cracks down low between the sleeves the block is JUNK.
It is cracked between the cylinders. I had coolant in the cylinders but upon inspecting the gasket, it was junk. I'm now assuming the block is okay and that all the coolant came from the crappy gasket
I have one in Alabama. It's stuck.....but
you can have it if you want it. It's a
complete engine. Missing the carb. And
magneto is cracked. Maybe an easy re
build.
Couple pictures
Paul in Missouri has a block with parts. Classified photo ads on this site. Ad number is 706611. $100.00
