Anonymous-0
Heres the deal my dad has always wanted a hand start model A. So I found him one, the tractor ran great had a few minor oil leaks held water and fluids just fine. We decided to strip it done a little to clean it up and paint it. Nothing major just pulled the tins, valve cover, replaced manifold, and pulled rear breaks. Didn't mess with any mechaninical. While we had it apart to sand blast and paint we drained all the fluids rear end, engine oil, and the radiator and water from the block. Well after we put everything back together we filled it with oil "the rear end and the motor" and filled the radiator. We then got the tractor to fire up and just let it sit and idle keeping an eye on the water. We noticed we had to keep putting alot of water in it. After runnin for about 20 minutes we noticed water leaking around the fly wheel and the cluth. So I shut it down. Out of curiosity I opened where you check the oil under the clutch and got about five gallons of water out of there. Then outa curiosity I pulled the fill plug outta the rear end and white milky oil came pouring out obviously now way over filled with oil and water. Does anybody have any ideas what could be causing this to happen? How I could possibly be getting water from the radiator all the way to the rear end??? Any ideas or suggestions would be greatly appreciated. We finally got this tractor looking great now we just need to get it running good again. Like I said when we started this project it ran great with no problems.
