1943 Slant Dash Throttle Linkage
oldcartech
I bought my first John Deere and it was in boxes! It's a 1943 A Slant Dash serial # 520799.
There was not any throttle linkages in the boxes so I made some out of 1 /4 rod. The tractor is back together and running but now I realize that my homemade throttle linkage is overcoming the governor. When I pull my throttle lever all the way back the throttle plate is wide open.
I've been reading about the governor operation in a B model repair book and from what I can understand is that with the throttle lever pulled all the way back, with a unloaded engine, the maximum engine speed should be around 1375 RPM. That seem right?
Does anyone have a similar tractor that can measure both throttle rod lengths for me? Or give me advice on how to make to correct length rods?
Sincerely,
Mike Ruppel
Take a look at the [b:654c4848f0]THROTTLE CONTROL[/b:654c4848f0] diagram below.
Note the throttle rod (Key 4) and speed control rod (Key 7).
If these two rods are installed on a tractor, then there is no way to measure the entire thread length.
These two rods are designed for 1939 through mid 1947 Model A tractors.
