Anonymous-0
1944 Farmall M
I need to replace the inner and outer tie rod ends and the adjustment sleeves on the front axle, my problem is I don't know which wide front I have, there aren't any tags or stamped numbers for identification, the adjustment sleeves don't resemble anything for a Schwartz or a Spee-Co axle that I can find, maybe this axle is a newer IHC axle from a SM, 400 or 560 or larger tractor, I don't know. I thank you in advance for your help.
